I have had my Virgin V HD box now for almost couple of months seems good fine HD picture on the 3 free channels that i get no real complaints there.
Anyway yesterday i went out to get a new front door bell as the old one was water damaged, fitted it great no problems at all. The new door bell is wireless.
About an hour later whilst watching the tv, my V HD box suddenly turned it self off & rebooted, thinking this was an update of some kind, i paid it no notice as i know there are supposed to be some new channels coming either in June or July ( Film 4 HD is one of them & a cookery channel in HD ). Then this happened again about 1/2 an hour later & again after another 10 minutes, so i did what Virgin usually tell you, re-started the box after leaving for a few minutes. This went ok but again it rebooted itself after another 20 mins, so thiinking that the wireles doorbell may be interfering with it i removed the indoor mains plugged sender reciever box which happened to be around 2 feet away from the HD box & did another restart on the box. Great i thought after around 1/2 an hour with no problems must be that, caused by RFI, no wrong it started again after another 1/2 hour & kept doing it every 10 minuites or so. In the end I turned it off totally & have left it all night.
Before i start it up this morning has anyone else had a similar problem? cos it looks like i might be getting into an argument with Virgin for a new box this morning.
