Not sure what cartridge it had - but you've got a removable headshell - which makes the fitting of an Audio Technica AT VM-95E an easy job 👍I have just bought the above deck, can anyone advise me what cartridge I need for it Thank you
Standard cartridge fitting so pretty much anything will fit. Depends on how much you want to spend.I have just bought the above deck, can anyone advise me what cartridge I need for it Thank you
To be fair you might need a protractor in any case. Not all tonearms are equal..1/ Cartridge pre-wired into headshell & pops in seconds - ortofon & many others
2/ Cartridge with built in headshell & pops in seconds - ortofon
2/ Cartridge & fit to headshell
you will need a protractor & test record for best results or dealer to Fit cartridge
3View attachment 6404
Yes, this would save you a little bit of time....but lose you a fair bit of money - and you'd still need to slacken off the fixings and align it properly:To be fair you might need a protractor in any case. Not all tonearms are equal..
