Video to digital
nads
1,145
463
19,570
thinking about putting some Videos i have onto disc. Any pointers? i have a video player and a DVD burner and software on the PC. is is as simple as i think? just plug it in?
As long as you've got a port to plug it into on your PC and you've got some editing software to import into, it should work. I use a Mac and you can hook the VCR into a camcorder via the composite in, then connect this into the Mac via Firewire / USB. Video can then be imported into iMovie and then exported into iDVD or Toast or whatever your burning software is.
I'd assume it would be the same for PC, just a different piece of software in place of iMovie.
