newlash09 said:
But as posted in my previous thread titled ' why hifi costs so much', I had heard the B&W 800 series diamond floor standers with a ayon tubed pre-amp. And i have never heard treble like that before. And that coming from me is big, becuase i cant really hear differences even between dacs. And i thought it was the diamond tweeters, till my other listening friend told me it was becsause of the tubes.
So was my friend right. Was it the speakers or the tube pre-amp. And can i get a tube buffer in my setup to get the same rich sound sound and the smooth treble.
Though I didnt mention that here, apart from the way the treble and strings sounded, female vocals felt so real, it was like the singer was in the room. I never experienced that before, but read it only in reviews.
But unfortunately tubes are very expensive, and most reading also seems to indicate that they need more care and service like a car
So was thinking that adding a tube pre-amp or tube buffer will be an cheaper option, if it works
Looks like you’ve been bitten by the Tube sound. Welcome.
IMO the only way to fully scratch that itch is to go fully Tube. A ‘Tube buffer’, whatever that means, will only make you hungry for more.
There are certain sound qualities that only Tubes will give you. That natural treble that you heard is one of them. It makes strings, percussion and voices have an ‘in the room’ realness that almost all SS Amps cannot quite pull off. My Devialet comes close, but isn’t quite as 3 dimensional as my S8.
