- Aug 10, 2019
- 2,556
- 5
- 0
Hi, I was wondering if anyone can help me?
I borrowed a working Fatman itube 252 from a friend and got it home. I wired it up and switched it on. There were a few crackles from the speakers and flashes from one of the power tubes (no smell of burning). Then the left channel did not produce any sound.
I thought this was the tube so swapped tubes over expecting the problem to migrate to the right channel. Problem solved? No. The left channel still does not work. Swapped over tubes, in sequence. No change.
Checked and swapped interconnect connections. Left does not work.
Checked and swapped speaker connections. Left does not work.
So it seems that the tubes and connections are fine. Does anyone know how to fix this?
By the way, speaker hiss can be heard in the left channel speaker.
If anyone has any suggestions, I would be extremely grateful.
Best regards,
Lee
Best regards,
Lee
