D.J.KRIME:the_lhc:Yes that's exactly what I thought, not sure why Andrew was agreeing with bigboss.
Nor am I. Sky will transmit all 3D as a passive signal @1080i/50htz via its standard HD box so in theory any HD TV sholud display the image being transmited in exactly the same way as there is no actual differance to the way your Sky box and TV work to dispaly this passive 3D signal, it just you will see both left and right images on screen at the same time without polorised glasses in exactly the same way as it work at the cinema. If it is then possible to find a pair of polorised glasses that work with older TVs to seperate both images properly for each eye is yet to be seen, but I have a huge collection I have keept from recent cinema visits(includeing a iMAX pair) a will give them a go via the Sky demo channel.
No it won't work, the TV has no polarizing filter, the TV will just show two images but will have no way to distinguish them to your eyes, a normal TV has no method of polarizing the light coming from its screen, hence 3D doesn't work.
