What brand and price is suitably, and sounds good fore the money, for an USB Cable, for sound transfering from MacBook Pro to my USB DAC? It is a YBA D100 DAC.
MajorFubar said:...and just to fully grasp how stupid the idea is that 'HiFi' USB cables can make any difference at all, ask yourself if you'd expect to notice any different in your prints if you used one to conntect your printer to your PC. The suggestion I'm sure you'll agree is absolutely ludicrous, yet when the digital data is destined to be converted into music and not a picture, the rules are changed somehow...
It's a wonder that we discover anything if we believe everything is impossible.MajorFubar said:There cannot be any differences in sound in a digital cable.
spiny norman said:MajorFubar said:...and just to fully grasp how stupid the idea is that 'HiFi' USB cables can make any difference at all, ask yourself if you'd expect to notice any different in your prints if you used one to conntect your printer to your PC. The suggestion I'm sure you'll agree is absolutely ludicrous, yet when the digital data is destined to be converted into music and not a picture, the rules are changed somehow...
Gosh, that's an original analogy: never heard that one before!
David@FrankHarvey said:It's a wonder that we discover anything if we believe everything is impossible.MajorFubar said:There cannot be any differences in sound in a digital cable.?
More specifically, it's a case of being open minded. Have you tried various USB cables?Laurens_B said:That is because believing has no part in discovering things.
Just because it's irrelevant unless you believe in the simplistic 'digits is digits' doesn't make it any more pertinent to ths discussion.Laurens_B said:Just because it is used a lot and bores you does not make it any less valid.
spiny norman said:Just because it's irrelevant unless you believe in the simplistic 'digits is digits' doesn't make it any more pertinent to ths discussion.Laurens_B said:Just because it is used a lot and bores you does not make it any less valid.
The joy of forums.MajorFubar said:Spreading silly voodoo that says otherwise just confuses people like the OP and leaves him uncertain of who to believe.
David@FrankHarvey said:According to yourself, there is only one person to believe anyway.
David@FrankHarvey said:all I did was recommend he try some out. It costs nothing to try something for yourself.
