Upgrading parents system - need recommendations for Freeview recorder
As a birthday surprise for my dad I'm looking to buy him a replacement for his TV and DVD recorder (which is on its last legs)
That was the easy bit and I've found a TV and a Blu Ray player that I think he'll be happy with
The problem I'm left with is the DVD recorder funtionality - I know I can replace his old freeview box with a HD freeview PVR box but I know he'll want to keep some recordings indefinitely (or more to the point I know my mum will easily fill up 200 hours on the harddisk with programs she'll watch "later" [😉])
Can anyone recommend a HD freeview PVR box that will easily allow programs to be saved to, say, a USB flash drive - or do I have to look at one with a built in blu ray recorder?
Thanks in advance for your hrlp
Just got back of holiday - thanks for the suggestion - dumb question coming up........
Will a Freeview HD box pick up the non HD signal if you're in a non HD area or will it just get static?
Narked Diver:
Will a Freeview HD box pick up the non HD signal if you're in a non HD area Yes, Freeview HD boxes are capable of receiving SD channels.
Cheers - the HD signal won't be available in my folks area for a couple of months and I was concerned if I did the upgrade now they would have nothing to watch 🙂
