Simple question.... I'm going to upgrade my TT. I'll have £600. I'll be listening to some this weekend.
Recommendations?
Recommendations?
chris_bates1974 said:Simple question.... I'm going to upgrade my TT. I'll have £600. I'll be listening to some this weekend.
Recommendations?
chris_bates1974 said:OK, ideally needs to be new - although second-hand from a dealer would be ok. Do want it to come with a cart, as will likely upgrade later. Absolutely must have a dust cover. I would prefer belt driven - nothing that looks like it should be used by a dj.
I hope that helps! I've seen the advice you've given others Al, so looking forward to seeing what you've got to say on this,
Thanks!
chris_bates1974 said:Hi, I will need a phono stage... I hadn't thought about spending massively on the cartridge first up as opposed to spending a little more on the TT to start with... Funnily enough, the Debut Carbon is one I am booked to listen to this weekend, and I like the look of it. It does come with a 2M Red - which is what I have currently - I wasn't aware it could be bought either without, or with a different cartridge....
Wondering if anyone has compared the new Planar 2 with similar priced models from Pro-Ject?
Mark Rose-Smith said:I think if your sticking with the ortofon.....a 2m blue at least will give you a decent boost in Sq.......maybe a different way to go about this upgrade would be to buy a decent cart and phono stage followed by the turntable at a later date.I think this will give you more bang for your buck at the moment....If it was me I'd be going for a good used stage at around £400 and then a decent mm cart around the £200 mark.......if it was me! Then I'd save for the turntable.
Not quite literally... In a dealer, unless they have a superb listening room, the subtleties of a better TT might well go undetected. At home, you certainly would notice a difference in background noise, and maybe in speed stability.chris_bates1974 said:Ok, I may open a massive can of worms here... but, does that mean that you're saying I could have a £150 turntable, and a £1000 turntable, but putting a (for instance) £500 arm and cartridge combo on them would basically make them sounds as near as damn it the same?
This could turn out to be more complex thatn I had thought....
nopiano said:Not quite literally... In a dealer, unless they have a superb listening room, the subtleties of a better TT might well go undetected. At home, you certainly would notice a difference in background noise, and maybe in speed stability.chris_bates1974 said:Ok, I may open a massive can of worms here... but, does that mean that you're saying I could have a £150 turntable, and a £1000 turntable, but putting a (for instance) £500 arm and cartridge combo on them would basically make them sounds as near as damn it the same?
chris_bates1974 said:Thanks everyone... Seems like something around the 300 mark with around 200 on the cart might be the way to go? Or....
Would my current TT take a new arm? It might be that could be a way also, it seems....
Although, if I stick with the current TT, would using the onboard phono stage (which I would not know how to bypass) mean that I would always be limited?
I'm so confused!!!! But happily so....
Al ears said:chris_bates1974 said:Thanks everyone... Seems like something around the 300 mark with around 200 on the cart might be the way to go? Or....
Do you have an instruction manual for that turntable? Most with phono preamps are switchable so you can bypass the phono section and use an external upgraded one.
chris_bates1974 said:Al ears said:chris_bates1974 said:Thanks everyone... Seems like something around the 300 mark with around 200 on the cart might be the way to go? Or....
I don't know, is the honest answer - I don't have a manual.... I have emailed Henley - I will wait and see what they say.
In all honesty, I'm intrigued at the thought of upgrading what I have...
Sounds promising, and glad to read that you got great service. If only more folks would take the trouble to audition properly.chris_bates1974 said:Well, I've been in for a listen. Hifix very kindly got as close to my system as they could with current kit, so Cyrus amplification and KEF speakers were set up when I arrived, with the Planar 2 set up and ready to go, phono amp duties handled by Rega mini Fono.
I was initially impressed, but as I listened more, I started to feel the limitations of the cartridge. It was perfectly nice, but ultimately I felt not quite as detailed as what I have already.
Next the TT was swapped out for the Debut Carbon... Wow! the difference was immediate, and the step up in cart instantly noticeable. There was more "there" and the sound was just superb.
I then asked if the Rega Fono MkII could be added in, and nothing was too much trouble! Once again, there was a step change in performance, with the Rega seemingly exerting some kind of extra grip on everything. I've never heard bass as crisp!
Credit where it is due, Hifix certainly looked after me, with a couple of coffees being more than welcome after what had already been a long day.
The upshot is that I'm pretty sure I'm going to go for the Debut Carbon and Fono combination. I like the sound of the Ortofon cart (I already have one) and the rest of the pieces fit together beautifully. I'm not sure I could do much better for less than a grand. And I know where I'll be buying them.... I guess I'll spend the rest on records!!!!!
And the Red can be upgraded to a Blue with just a stylus change; see if the dealer can do you a deal if you can afford it. (You doubtless realise they are imported by the same company).chris_bates1974 said:I liked the Fono mini, and to be fair, it was probably let down a little by the Rega Carbon cart fitted to the Planar 2. For me, the overall package of Fono MkII with the Debut Carbon and 2M Red gave me what I was looking for....
The only problem now is that it's about 6 weeks until I can buy them!!!!
Freddy58 said:chris_bates1974 said:I liked the Fono mini, and to be fair, it was probably let down a little by the Rega Carbon cart fitted to the Planar 2. For me, the overall package of Fono MkII with the Debut Carbon and 2M Red gave me what I was looking for....
A pity you weren't able to listen to the RP2 with a decent cartridge.
