JohnNB said:
I have an Thorens TD160 tt with a Logic Basic tonearm played through a Roksan Kandy amp and a Rega Mini Phono stage into Spendor SP1 speakers. I recently replaced an Orofon cartirdge with a Golding 2100. The Ortofon was lively and bright and I'm dissappointed with the dull sound of the Goldring. Can anyone advise if I should go for a different phono stage to liven up the sound from the cartridge, or should I replace the cartridge?
JohnNB
Good record players are expensive, require careful matching of TT to arm and cartridge, careful setting up and proper support.
I have no real idea how well or otherwise your current combination works, though clearly not well by your opening post. Recent experience suggest that few dealers have much of an idea about setting up and matching such combinations so results in cases like this can be hit or miss.
This is one reason, I think, for the move to more 'integrated', almost plug and play solution from Rega, Project, Clearaudio and the like.
In your situation I would do the following.
Go back to the Ortofon, buy a new stylus or a replacement unit as appropriate.
Go to a Linn dealer and get him to show you how to setup up the arm, including how to remove the arm and fit the cartridge properly. If you do not have them, get him to supply you with some headshell fixing bolts and the allen key to fit them. Make sure you also have the correct allen key to unlock the arm piller and remove the arm.
Care fully unlock the arm, lift it out from the mount, unplugging the arm cable as you go. Then remove the fitted cartridge carefull using long nosed plyers to handle the tags.
Then fit you new cartridge using the new bolts, if the stylus is removable it is easier to do this with it removed. Do the bolts up tight, usually from underneath the cartridge. Set it in the center of the slots in the headshell and make sure the cartridge is absolukely straight, front to back. Use the slots as a guide, refit the stylus if it has been removed.
Refit the arm tightly, and adjust for tracking weight towards the higher end of the manufacturers guidlines, leave the bias on zero at this time and place the stylus on a stationary record. Set the arm so that it is very slightly higher at the pivot, ie the arm slpes down very gently to the stylus end. If the slope is obvious, it is too much, it should be very gentle. Set the bias to approx one half to two thirds of the tracking weight.
With the arm on it's rest check the suspension of the turntable, it should be able to move freely up and sown, about a quarter of an inch, without any catching or binding of any kind. Tap the platter firmly between the spindle and the arem pivot to check this.
Support the player on a light rigid support, a table or minimalsist shelf, avoid heavy furniture. Make sure the support is firm, that it does not rock or rattle and that the surface supporting the player is horizontal.
You are good to go.
