Hello,
Got constant upgrade fever *scratch_one-s_head* Currently got Rega RP1, Marantz CD6005, 2014 Macbook air with Audioquest Deagonfly v1.2 running TIDAL using decent cable to Zensor 3's on Pixel stands.
My amplifier is Pioneer A20 which is doing the job well, but I feel as though there could be more ??? I have a max budget of 300 pounds to change amp, looking at the obvious Marantz PM6005, have also looked at NAD 316bee, I listen later in evening at mostly lower volumes to floyd, zeppelin etc.
Is it a worthwhile move or should i stick with what I have ?
Many thanks for any wisdom you may share with me.
