I've not wall mounted a TV before and thought this was going to be relatively simple but there now seems to be an absolutely huge range of mounts from £10 upwards.
The TV is a 50" Panasonic Plasma P50GT60. It's going to be mounted on a wall with a pair of Monitor Audio Radius floorstanders to either side. There are going to be shelves around the 'media' area of the wall that will be about 300mm deep. That means I don't actually want the TV to sit partiularly tightly agaisnt the wall. Viewing will be straight on so not tilt or swivel required so I though a simple fixed mount would be ideal.
However, all of the mounts i can find all sell themselves as 'ultra slim' and look like they leave no space for plugs or cables behind.
Any recommendations for brands to look at? Are there any fixed mounts that are not so flush or do I need to be looking at 'full motion' mounts to get a TV to sit more than a few cm from the wall (not much - probably 50/60mm or so)
