Has any one with tv and a projector compare the picture quality of both and which one gives better picture quality.This question is more to those that have both a tv and projector as I cant decide if to buy a tv or projector.
cheeseboy said:depends what you want to use it for.
Watching tv etc on a pj is a waste really as the bulb life is finite and expensive to replace, plus depending on the light you may have to close the curtains etc in order to see it properly.
ibl0010 said:Oh forgot to say that if i go the pj route it will only be used at weekend occasionally for football, movie and hd (i will have a smaller tv for new and boring programes). I can control sun light from outside but the room is white ceiling and magnolia wall. To me picture quality and the expense of bulb replacement is the reason i can't decide if to just buy a bigger tv now or a small tv with a projector.
cheeseboy said:ibl0010 said:Oh forgot to say that if i go the pj route it will only be used at weekend occasionally for football, movie and hd (i will have a smaller tv for new and boring programes). I can control sun light from outside but the room is white ceiling and magnolia wall. To me picture quality and the expense of bulb replacement is the reason i can't decide if to just buy a bigger tv now or a small tv with a projector.
I'll be honest, it's a tricky one. If you've got full surround already and stuff like that, then I don't think you can really beat a projector for that cinema/big match feel. And that kind of trumps picture quality in that respect if it makes sense?
BowserWilkens said:I would say that if you're considering a 65" projector screen, just buy a 65" tv.
It's not only the picture quality but also the scale that is important with a projection screen.
Anything over 90" is just so much more imposing and dramatic - any loss in PQ is quickly forgiven, not that there should be much loss if you set up your projector diligently.
ibl0010 said:Has any one with tv and a projector compare the picture quality of both and which one gives better picture quality.This question is more to those that have both a tv and projector as I cant decide if to buy a tv or projector.
