TV recorder + HD issues
Portoman
42
Hi
I've been using a Thomson box to record programmes but got rid of it at Christmas as it kept missing recordings. I got a Humax as a present so connected it up the same way through my t.v.
My tv is a Panasonic Viera TX with Freeview and I have the aerial from outside going to the recorder box and a HDMI going from the box to the tv. - I also have a scart from the recorder to a scart box which then connects to the tv. (I also have Samsung Home Cinema connected to the tv you see). Before I did this, there were no problems but since I have reconnected it, I have trouble watching HD channels on Humax and Panasonic i.e. it says the signal is too weak or not there, whereas the other channels are okay. I have tried to connect the aerial direct to the tv but the connector wont stay in.
Any ideas ?
Portoman
42
I cant actually remember why I used the Scart cables as I connected it all up sometime ago, but I think it was when wanted to view different things via the tv, I would choose a scart from the scart box. Maybe they are obsolete now but part of me is loathe to disconnect it all as I fear I might not be able to put it back again.
However, the problem is : why am I unable to view the HD channels ? Has something gone wrong in the connections - do they need a stronger signal than non HD ? Also, as I said above, the outside aerial goes to the recorder box and a HDMI goes from the box to the t.v. - so the tv will only receive the aerial signal when the recorder box is switched on (this was never needed with the Thomson by the way)
daveh75
Well that isn't right for a start. HDMI doesn't carry aerial signals.
The aerial should be connected to the aerial input on the recorder, then its RF out connected to the aerial input on the TV.
I think you need to clarify your setup too, since your op is confusing.
You mention Humax, Panasonic and a recorder box.
