Hello all, hoping you can help with some advice/recommendations.
I'm hoing to be upgrading my turntable in a couple of months when funds permit, and would appreciate some guidance.
I own a few hundred LPs which I bought back in the day and have started buying some new vinyl. I currently play them on my Project Debut, through a Cambridge Audio Azur 551P connected to an AVI Lab Series Integrated and AVI Duo speakers.
The two contenders at the moment are the new Rega Planar 3 and Clearaudio Concept. I realise that the Concept is probably a step up from the Rega but both would surely be a big step up from the Project.
I'm comparing these turntables as follows:-
Pros - Rega is less expensive, has a lid, a matching phono stage and power supply, both of which could be purchased later as further upgrades.
Cons - In basic form the Rega's platter requires removal to change speed.
Pros - The Clearaudio is more of a high end design with sound and build quality to match. Plug and play.
Cons - No lid, which will have to be bought separately.
My old vinyl collection is mainly rock/prog with some jazz and blues thrown in i.e. Zep, Rush, ACDC, Bowie, Yes, Genesis, VH, SRV, Sabbath etc...
I'd be grateful for any comments.
Thanks.
DD
Thanks.
DD
