Toslink to Coaxal convertors
Hi all,
It's been a while since my last post and since then I've dragged myself into the digital age and set up a Vortex Box system on an AsRock ION 330 based mini PC.
I had hoped to output the FLAC content to my Musical Fidelity X-DAC V8 via the TOSLink output on the ASRock but alas, it appears that the X-DAC only has Coaxal or USB digital inputs. USB works fine but I wondered if the results would be better using Coaxal inputs? To this end, I was thinking of buying a TOSLink to Coaxal convertor and wondered if any one had any experience of them?
Also I wondered if adding such a convertor was worthwhile over the existing USB inputs as I wasn't sure if by adding another piece of kit into the mix would negate any benefits Coaxal would have over USB anyway?
Hope this makes sense.
Regards
Aeis
From what I have been led to believe USB is superior to Toshlink so I doubt you will get any improvement, plus you adding more links and connections in to the chain which themselves may add errors, personally I would stick with what you have already.
Isn't toslink, being optical, immune to groundwire differences, hence hum? In contrast, coxaial isn't, hence is.
Sure, there's the prospect of jitter over optical.
