Thoughts on a REL R205 Sub - anyone
Hi All,
Is anyone using a REL R205 sub in their system?
My plan is to integrate it into a MA Radius HD set up (225 & 180 HD's)
Other than the REL any other ideas welcomed.
Cheers.
This sub is so bad that no one uses it then?
Strange how so many different companies seem to have them in their demo rooms then !
I have heard the R205 and it seems v.good to me, so I will do that which is probably best - go with my own ears on this one.
Would have been nice to have some feedback though.
Regards.
Messiah
Don't use one so can't help you on that count.
But as you have already determined, if it sounds very good to you then that is what matters.
(Try not to be put of by the lack of responses - maybe not many people use the REL sub?)
