I am thinking about an upgrade but wondering whether it is worth it. I currently have a 55inch Samsung LED which is 12 years old (so not 4k). I think it has a good picture but have standards significantly improved in that time?
This would be a significant upgrade and you get a free quality soundbar and sub too:I am thinking about an upgrade but wondering whether it is worth it. I currently have a 55inch Samsung LED which is 12 years old (so not 4k). I think it has a good picture but have standards significantly improved in that time?
Same with my wife unfortunately.....Only you can decide whether it’s worth it.
Have you seen any 4K content? How do YOU feel it compares?
I have a 4K TV and some 4K content can be stunning, but, I am still really impressed with Full HD Blu-Ray.
Where I feel 4K plays a part is in screen size. With 4K you can get away with a larger screen in comparison to a Full HD set at the same viewing distance.
(My Mum and Wife (just to name 2) still don’t get it when I get them to watch the HD version of a channel over the SD channel! 😩)
It just seems easier (and more logical) for many people to press 1 rather than 101 on Freeview.....repeatedly telling them why they shouldn't doesn't work - because they don't care 🤨.(My Mum and Wife (just to name 2) still don’t get it when I get them to watch the HD version of a channel over the SD channel! 😩)
I have a 75-inch screen for 12ft viewing distance and it's brilliant!Thanks for the replies. I have seen 4k on a 50inch from about 12ft and I didn't notice much difference from HD.
I was thinking of increasing size to 65 inch. My viewing distance is 12-15ft. Plenty of room for that size tv. The current 55inch doesn't dominate the room by any means.
Another reason for thinking of an upgrade is that apps are gradually disappearing. The only common one left is iPlayer.
My wife follows a trend and can't see much difference between SD and HD!
I don't think my wife would tolerate something that big!I have a 75-inch screen for 12ft viewing distance and it's brilliant!
Go back to whomever you bought it from - you'll be under warranty.I took the plunge and ordered the s95c. Great picture but...
After watching for a while TV turned itself off. Turned it back on. Turned off after a few seconds. Did this a dozen times in a row. I could even check settings because it kept turning off. Kept getting screen optimisation message on screen and said it would reset after turning off. It didn't!
Managed to check settings. All eco stuff turned off. Unplugged for several minutes. Still no good.
What is going on? I can't live with a TV I can't use.
I have had several Samsung TVs that turned themselves on and off and always got a refund. The one connect box on the Samsung S95C seems more temperamental than the Samsung S90C TV without one.I have been in contact with the seller. Awaiting call back.
Richer Sounds. Not got back to me but not pushing it as away this weekend.Is it a brand new TV you ordered? From a shop or a private seller?
You know what you should do, you should call them.Richer Sounds. Not got back to me but not pushing it as away this weekend.
They're amongst the best in business. You'll be fine.Richer Sounds. Not got back to me but not pushing it as away this weekend.
