There still not much in it. The OLED is slightly blacker whereas the QLED is slightly brighter. Even when you see the comparison videos on HDTVTest on YouTube there still isn’t much in it.Try watching in a dark room and from a slight angle! 😉
Yep, correct. Looking back buying the LG OLED TV wasn’t one of my best ideas! I suppose I had to see it in person though. No more of those type of purchases.That's why I keep maintaining; there's no point in wasting money on upgrading perfectly functional TVs.
Cool.QD-OLED for me maybe next year when the second iteration comes along. Still enjoying the Kuro tho so who knows, maybe the year after!
Virtually the same comparing side by side.
They look good in the showroom being fed 8k or 4k signal from a dedicated source. Get them home and the compressed signal fed from terrestrial, satellite or fibre sources levels out any technical advantage. I can happily watch and enjoy black and white films without worrying about specification hype.The subtle differences I could see when comparing the Samsung Qled to my LG OLED was my OLED was better for contrast, shadow details, uniformity, and motion.
Yes. At the factory TVs are defaulted to Dynamic and Vivid picture settings. When you get your TV home go into picture settings and select Normal or other options. Then there are the contrast, brightness and sharpness controls which can be adjusted to suit you personally.I see no improvement with 8K over 4K streams to be honest. Most cable TV channels are at least HD today, so it's not hard to find a modern, with a high-performance TV set. I mostly watch Amazon Prime, and other streaming platforms and the performance is great for me. LG, and Sony do a tremendous job with upscaling images. TV settings are usually the culprit to a poor performance.
Retail stores purposely tune TV sets to look as bright as possible to get your attention by raising the brightness level of the set on the shop floor. At a glance, the picture of the TV will then look so bright and sharp that you will want to bring the TV home.
But here’s the problem if you look at the in-store set for more than a couple of minutes, you will notice that the detail is fuzzy. It occurs when the luminance level is too high on your TV. You will also see more blooming leakage in the black bars etc.
You can get a much better picture out of your TV by calibrating it. I have the software and tools to do this to my TVs, which really improves the shadow details as the OLED panels have black crush issues from the out of the box settings which leads to a loss of shadow detail. A proper calibration will iron out colours as well for a better overall image to remove a tint or hue from the TV panel.
true, anyone would see the difference between oled or qled, especially in the darkThe subtle differences I could see when comparing the Samsung Qled to my LG OLED was my OLED was better for contrast, shadow details, uniformity, and motion.
I sit 9 feet away from my 75-inch TV that's on a stand, and it's absolutely perfect. Bigger the screen, better it is. Your eyes get used to it pretty quickly. Watching movies is spectacular.Comparing ie 65 inch TVs or even 70 inch wall mounted gear. This also leads me to ask why so big a screen .
It has to be wall mounted and should only be watched at further than a certain distance in the house hold , and unless you have a huge room or a cinema room it is pointless getting the far more expensive 70 inch when a 55 inch will do just as good and cheaper at the normal height.
I reckon to watch a 70 inch have to be at least 15 ft away maybe further . We have a 46 inch Tv and we are 8ft away from it . That is about right to me .
Think 9ft is too close yes your eyes do get use to it but i always take advice on a manufacturers advice on distance to watch . They do these tests advisory . Off Course you can ignore this advice or advice from "spec savers" As you guys know not a fan of wall mounting there are a number of reason 1 paper walls unless a brick wall i would not fit a 72inch on any wall , but on a big table at a certain height recommended by the manufacture 2. distance is important from the wall 3 heat build up the amount of guys who fit that TV over a fire or radiator why there ? the worse place to fit one and will damage a TV and could well lose months of good use , by putting it there . This is the reason why i say you should not put it on any wall. . Do you really need a 70 or 65 inch TV or is it simply to impress next doors 55 inch ? 50 to 55 is well big enough for the vast majority of rooms . By the way i was offered a 108 inch Plasma last year for £250 worked great So heavy would need a crane and using 600 watts plus plus to drive itI sit 9 feet away from my 75-inch TV that's on a stand, and it's absolutely perfect. Bigger the screen, better it is. Your eyes get used to it pretty quickly. Watching movies is spectacular.
Of course, you follow manufacturers' recommended viewing distance.Think 9ft is too close yes your eyes do get use to it but i always take advice on a manufacturers advice on distance to watch . They do these tests advisory . Off Course you can ignore this advice or advice from "spec savers"
I'm curious about how my screen would look when viewing more closely, but am not sure I can be bothered to move the room around - seating position must be 4.5m away.The naked eye can't differentiate individual pixels when watching a 4K TV from this distance. This means that pixels effectively disappear when viewing 4K images. Thus, creating an impression of watching the image with the same detail and resolution as real life.
You can always increase the size of your TVI'm curious about how my screen would look when viewing more closely, but am not sure I can be bothered to move the room around - seating position must be 4.5m away.
I guess these distances rely on always watching 4k, as opposed to upscaled images. HD upscales pretty well, but is obviously less good than UHD, and SD upscaled varies massively.
