Not all amps have them on display.PS: this thread needs some pics from valve amp owners. Disregarding how they sound, they look cool!
would also have liked to post a pic, but can’t do it from phone!It's too complex trying to get pics on this site....God knows I've tried.
plenty without the sticky ups!😀Also, like Class A amps, they need time to warm up before they perform at their best, usually around 20 minutes or so. Life's too short.
And subjectively, they are ugly with the sticky up valves. That is just for my taste.
LS5/9s me! You?EDIT : @SallyB I too have mine partnered with Graham Audio speakers.
There are but tend to suffer from overheating issues. That's why all valve or tube and Class A amps need to be placed on top of a shelf, where my poky Class AB amp doesn’t have those restrictions.plenty without the sticky ups!😀
Woof!
My last transistor amp - 20 years, never any need for repair or service.I've had my amp 14 years and never replaced anything.
Thank you for this excellent video reference on the subject, I don't agree that "it's NOT about 'which sounds best,'" though. Minutes about 10:00 to 15:00 are interesting and instructive for me, and very much on the question, even if the gents don't provide a simplistic "which" answer. It's also a good reference for the rest of your helpful post. Thanks again for your 2cents+.The old 'tube vs solid state' debate.
This video on YouTube from Audioholics is interesting (it's NOT about "which sounds best", so don't be put off by the title).
View: https://www.youtube.com/watch?v=JT1iqlPMAnA
Many folks here are about 'digital' 'bit perfect' 'trying to keep the sound as close to the originally recorded sound as possible' no?
Well obviously tube amps don't do any of that. Due to their inherent properties they always color and alter the sound. They are basically one big tone control that can be 'tinkered with' at a high cost to the user (tubes are $35 - $300 a piece now).
Ironically, tube amp. manufacturers have tried to emulate solid state characteristics over the years by designing out the inherent flaws of tubes! e.g. by going to A/B push pull and by using more tubes to achieve enough power to drive large speakers before the tubes start to distort.
Many, like McIntosh, are now offering hybrid amps so that they can achieve the kind of power output necessary to drive large speakers without producing distortion. And then there is the output transformers required (critical to the design) which need to be big, heavy and expensive!
It's a measurable fact that tube amps are highly reactive (which changes the tonal balance of the input signal as the power output changes), they add noise and distortion and are less reliable than SS amps.
I love tubes for guitar amplification, but that's exactly because of the grit, grind and harmonic distortion they produce when pushed, I'm not sure that I want that in my music 'reproduction' system.
As I said, most decent tubes not cheap and I don't see the point of owning a cheap valve amp with cheap tubes because it'll become expensive in the long run.Like everything in Hifi, there are cheap and mega expensive valves!😀
That was my point. The valves have a limited shelf life.Has any valve amp lasted as long with no attention whatsoever? 🤔
True.That was my point. The valves have a limited shelf life.
Mrs. Ps brother has just purchased a Tesla Model 3 used car, and as I explained to Mrs. P Tesla only gives their batteries 8 years lifespan from new. And they're not cheap to replace.
My old Alfa, by contrast, is 19 years old, over twice as old as Tesla batteries.
I'm sure in the right environment, the right speakers and room, tube amps are very good. Just too much hassle to feel comfortable.True.
Valves are like light bulbs, limited life span and you never know when they are going to go.
That said a good valve amp paired with the right speakers can make some wonderful noise....
Actually, they don't have a limited shelf life.That was my point. The valves have a limited shelf life.
Limited useage time then perhaps not shelf life.Actually, they don't have a limited shelf life.
NOS tubes manufactured in the 50' and 60's fetch premium prices and are quite rare.
e.g. these 'tested' CBS 7025/12ax7's that were made in the 50's go for around $500 for a matched pair.
Agree over positioning issue. Mine was a swine to position safely on a top shelf. However, if aesthetically they are your thing, then you don’t want them hidden away.There are but tend to suffer from overheating issues. That's why all valve or tube and Class A amps need to be placed on top of a shelf, where my poky Class AB amp doesn’t have those restrictions.
Heard the stand-mount version when auditioning speakers - nice, but I’m guessing that the floor standing version gives you more bass extension.
Fair play. However, at $250 each isn't cheap, especially if you're on a budget. As @Al ears correctly mentioned unless you're prepared to spend a substantial amount on a tube amp, it's always best to choose a SS amp.Actually, they don't have a limited shelf life.
I wouldn't want any limit to the usage life of those 🤨e.g. these 'tested' CBS 7025/12ax7's that were made in the 50's go for around $500 for a matched pair.
Very nice...View attachment 6424
Finally worked out how to post photo of my amp from an iPhone (hopefully)
www.psaudio.com
