Well after many, many years being happy with my older RP3 with 300 arm it has finally gone to be replaced with a PJ 1x carbon. Decided upon this a opposed to a new RP3 or upgrade to my current RP3 as I found the PJ was able to extract more detail from the vinyl than the RP, all be it delivered in a slightly more suitable/less aggressive manner than the RP did..in essence as per the What Hi Fi PJ 5* review.
The next question is what now to upgrade for my £500 budget; the amp or the speakers which are a Rotel RA-04SE and QAcoustic 2010is.
The essential/desirable are:
1) Amp must be able to run two pairs of speakers.
2) Speakers must be bookshelf
3) Essential to retain detail from PJ but would like to have a bit more drive to replace that lost when changed to RP if possible.
4) 2nd hand options would be considered
5) £500 budget in total but not all needs to be spent
Only thoughts I have so far are to keep amp and get a pair of KEF Q350 that I have been offered 2nd hand or B&W 607s.
Happy for any advice....oh and I am UK based
