acalex said:Another week before the last piece joins the family..... :cheer: :boohoo: :dance: :bounce: :rockout:
CnoEvil said:acalex said:Another week before the last piece joins the family..... :cheer: :boohoo: :dance: :bounce: :rockout:
I look forward to it, as it will make a pleasant diversion.......... :shifty: :silenced:
My DSM has hdmi. I use it with my ATV, TV receiver and my PS3.michael hoy said:Does your DS have the HDMI connection, just wondered what you use it for if it does.
marou said:The Majik DSM Sounds pretty good but unforgiving on poor recordings - the installation guy thought majikm109s would be better and offered me a trial. I'm dubious but happy to give them a shot. The Harbeths are perfect in every respect apart from middle register bass which can be a bit thuddy - the 109s may or may not identify the speakers as the source of this problem.
marou said:I'm not really a cable guy - seems like a slippery slope to me which might end up in moving house (shudders) - and the one box solution the DSM offers precludes an aditional amplifier. But as you've seen my opinions are not by any means written in stone - only recently the absence of an FM tuner was a dealbreaker as far as the DSM was concerned and look at me now.
acalex said:Well....the last member of the hi-fi family is finally home, connected in 5 minutes and up and running already. Realised that the same server software which I was using with Squeezebox is perfectly compatible with the Akurate...so very very good.
Also just found out Itunes 11 can stream directly to the Akurate...a big plus also!
CnoEvil said:acalex said:Well....the last member of the hi-fi family is finally home, connected in 5 minutes and up and running already. Realised that the same server software which I was using with Squeezebox is perfectly compatible with the Akurate...so very very good.
....and.......... :quest:
acalex said:Nils Lofgren sounds incredible...I might now try to connect the Linn Black cable to see if they are good enough as now I am using the 770i 😀
CnoEvil said:acalex said:Nils Lofgren sounds incredible...I might now try to connect the Linn Black cable to see if they are good enough as now I am using the 770i 😀
You really need something like the Linn Silver (or better).
I will be interested to see if your mains cable makes a difference to the ADS, that you can readily hear.
Nb. It looks lovely in black.
acalex said:Which ICs are you using with the DS? Also cardas?
CnoEvil said:acalex said:Which ICs are you using with the DS? Also cardas?
Yup.....but the Silvers are surprisingly good (now connected to an Arcam DV79).
acalex said:Now I put the 770i on the turntable and the 550i to the Akurate...it's impressing how better the sound becomes whenever I go up the ladder with this Siltech cables...but I am sure it's all a placebo effect and I am imagining all of this... :doh:
acalex said:I will try looking for the Silvers then...
Neuphonix said:Audioquest Sky? If you're looking for a silver interconnect. 🙂
I would have thought that copper might have a less edgy nature for the Akurate though?
CnoEvil said:acalex said:Now I put the 770i on the turntable and the 550i to the Akurate...it's impressing how better the sound becomes whenever I go up the ladder with this Siltech cables...but I am sure it's all a placebo effect and I am imagining all of this... :doh:
The difficulty is putting a value on any perceived improvement.
What happened when you replaced the Blacks with the 550i and the 550i with the 770i?
Can you hear a difference on the ADS between the 2 Siltechs?
acalex said:Now I am running the Akurate with 550i and phonostage with 770i.... :shifty:
CnoEvil said:acalex said:Now I am running the Akurate with 550i and phonostage with 770i.... :shifty:
....and... :wall:...... :rofl:
