Neuphonix said:hmmmm, I suspect that this thread has become infected with upgradatitis :?....
Neuphonix said:yes, extreme caution will be key, there's definitely no rush.
They have had them there for a while now so I should be able to go pretty hard on the price & it will only happen if they're willing to do a trade in on the Diablos.
But even then I doubt the funds are going to be available in the near future.
Damm my old man & his "rolling off around 40", he's forever planted that seed of doubt 😳
Will report findings.
acalex said:I guess it will be almost impossible to find over there, but just check to see if these Leedh E are available...if you can stand the design you might be positively surprised by those 🙂
http://www.leedh-acoustic.com (only in French)
CnoEvil said:acalex said:I guess it will be almost impossible to find over there, but just check to see if these Leedh E are available...if you can stand the design you might be positively surprised by those 🙂
Blimey, only the French could come up with that! :O
Neuphonix said:Amp section will stay the same Primo/AMS35P.
So if the 35P is not up to the job then they will not even be considered.
It should be OK though? Surely if the 35i can drive your Kefs Ok the 35p should manage the Scalas?
I know the AMS50 would have been more ideal but thats just getting plain ridiculous!
acalex said:I know that's a shame but if it happens to you to come across those speakers just try to have a quick listen and tell me please if my ears were fooling me yesterday or these speakers are really that good...
CnoEvil said:acalex said:I know that's a shame but if it happens to you to come across those speakers just try to have a quick listen and tell me please if my ears were fooling me yesterday or these speakers are really that good...
I'm almost certain that your ears weren't fooling you......you have heard too much good kit for that to happen. At this stage your standard is sky high, otherwise you would have enjoyed the first demo of the DS.
The speakers you end up with should be the right ones, given the big variety you have listened to. For me personally, I think it's a shame that neither you nor Rob have heard the Refs on the end of an AMS (with a DS), but I suspect you both have found what you've been looking for.
Roby said:Damn
You know I'm more a cdp man an yes at this point I have 3 in mind but only tried out 1 who was beautifful (the electrocompagniet).
But as I'm openminded I think I went with Alex to the first Linn pressentation....I had two words aftherwards "NOT CONVINCED"
An Alex already told you why....As I like the manipulation an the look of my cd collection, The guy struggeling with his set-up an connection was shurly not convincing.... an than using files from spotify :wall:
No he had the chance to have a prper demo an I was not there.....Just bad luck or is a sign I should stoy on the CDP pad... :?
There is a demo this evening this time I will not miss it :read:
Roby said:Damn
CnoEvil said:In case the Linn doesn't work out (which it will - with the right demo), another brilliant CDP I've come across that's worth bearing in mind, is the EAR Acute 111 (with Dac): http://www.stoneaudio.co.uk/?product=ear+acute+iii+valve+cd+player+with+dac
chebby said:CnoEvil said:In case the Linn doesn't work out (which it will - with the right demo), another brilliant CDP I've come across that's worth bearing in mind, is the EAR Acute 111 (with Dac): http://www.stoneaudio.co.uk/?product=ear+acute+iii+valve+cd+player+with+dac
Your link didn't work.
Try this...
clicky
CnoEvil said:chebby said:CnoEvil said:In case the Linn doesn't work out (which it will - with the right demo), another brilliant CDP I've come across that's worth bearing in mind, is the EAR Acute 111 (with Dac): http://www.stoneaudio.co.uk/?product=ear+acute+iii+valve+cd+player+with+dac
Try this...
clicky
Thank you....I usually check it, but didn't for some reason.
acalex said:Which are all in stock at Francis' :cheers:
There is also a nice deal on an ex-demo model, silver though :dance:
CnoEvil said:In case the Linn doesn't work out (which it will - with the right demo), another brilliant CDP I've come across that's worth bearing in mind, is the EAR Acute 111 (with Dac).
DocG said:Hi Cno,
When you say: a CDP with DAC, do you mean it's a transport + DAC, or can it be used as a DAC for other sources (i.e. does it have digital inputs)? Can't find the info right away on tinternet...
That's what holds me back from the Linn-route, at the moment: if you want a DS with a digital in, you need a DSM, with integrated pre+power amp (which I won't need) :wall: . Unless I misunderstand? :?
