The DAC scam
Status
Not open for further replies.
- you arent going to actually hear differences between DACs - you'll maybe hear differences due to slightly different volume levels, the way you're focusing on the music, etc etc. That's not actually differences with the sound coming out of the DACs though.
I genuinely believe you're wrong!
Just because YOU can't hear any difference, doesn't mean that other people can't.
I've just explained to you why you cannot reliably tell differences with subjective listening. You think you are hearing differences but they can be down to volume differences, focusing on different aspects of the sound each time, our poor memory of what we've heard, and placebo and expectation bias.
Unless you've conducted proper blind tests with volume matching you just don't know. I'm sorry but that's the way it is. And the measurements tell us differences are going to be VERY small.
Reactions: powerplay
Then there's something unmeasurable that makes some of them sound different. I'll take that Pepsi challenge with two DACs of my choice.
There isn't. It's most likely volume mismatch and expecting bias and the way we listen differently each time focusing in different areas of the music. Also your head being in a slightly different position relative to the speakers can also affect what you hear.
If you haven't ruled these known effects out by doing a volume match double blind test then you do not just start claiming there is something unmeasurable at work.
I know the consumer must be safeguarded from market elements. Businesses are like living entities, they need to feed in order to sustain and prosper and the main facet of the beast is the power of marketing.
YouTube has become the mantle for the next Messiah, especially those with wonky hair but if you look closer, it's just a different type of brand.
It's not a voice from the heavens, it's another business hiding behind the mask.
Nativity isn't unique, we had this inkling but now the Messiah has reassured and weaponised me with his words.
There is value from twisted tongues, the truth can come in all forms, what is important is your capacity to remain objective.
Attacking the messenger and ignoring the points made. Not a good look.
Sounds a bit straw-manny to me.
In the scenario every conceivable care was taken to ensure that both presentations were matched by the meticulous and independent store assistant / boffin in a white coat, but you still preferred the component that measured less well. Then what?
When does it ever happen that the store assistant checks volumes even with a dB meter? (which is t that accurate btw)
It's not a strawman - you cannot do subjective comparison of DACs and expect a reliable result. Especially in a store where it's a different room to the one you're used to and you'll be noticing different things because of the new room acoustics.
This is why auditioning equipment in stores is so pointless. Especially DACs as there's no significant measurable differences between them!
Reactions: powerplay and Dave_
No significant measurable differences between DACs? I seriously doubt that, simply because standalone DACs are hugely user configurable, and they do not all sound the same.
This is a slippery slope...
Well you can look at the measurements for yourself. If you're talking about filter changes most people use the default as it tends to be the best. But you can look at the measurements for each filter. If you haven't done that please do then get back as to whether you still doubt they all sound the same.
1. Devices that have measured similarly have not always sounded the same - that's a fallacy.
2. Manufacturers implement the DACs and may implement the analogue output stages differently as well.
So I'm still a bit dubious that they all sound the same.
What?
Messenger of Whom?
Is there some devine message from this blogger that excludes him from criticism?
I see you have your back against the wall but you need to understand, opinions are not linear and the absolute truth as you see it, is often watered down by best practice.
Never underestimate Subjectivity.
Like I said, I'll happily take that challenge.
If some people want to believe some headline grabbing YouTubers who can't be bothered to get a proper job, they're free to do so, and if that's why you're happy with the DAC you have, fair play to you. If some people don't want to get involved in any audio system that costs more than three figures, that's fine, but when they try to dismiss anything above three figures to everybody else, it starts coming across as jealousy or sour grapes.
Personally, it matters not a jot to me. If I've heard a difference, I know there's a difference, regardless of what anybody's measurements are, or however loud anybody shouts "there cannot be a difference".
I'm aware of the variables thank you very much, now take your condescending replies elsewhere. Don't tell me what I have or have not heard, or what I can or cannot hear.
No ... I'm sorry, you are completely and utterly WRONG!
I think you believe if you shout enough, everybody will cow-tail to what you're saying and you have absolutely no appreciation of other people's opinions or experience.
All my tests were volume matched at the beginning .... what really surprised me, I did it by ear 1st, then ran it through a meter using a Umik-1 and my ears wrere so unbelievably close to the meter I was genunely shocked, I thought there'd be a huge difference and there wasn't.
In term's of blind testing ... the instant major difference was the soundstage, at 1st I REALLY didn't like .... it as it was so far removed from what I was used to .... you'd have to have a serious hearing problem if you didn't notice so I needed no other proof that they sound different.
Anyway ... you continue comng in a telling everybody else they're wrong and you're the devine authority on it.
Oh .... and by the way .... 6 months ago I would have thought you were totally right but I didn't go into forums preaching my beliefs to everybody ... I've subesequently experienced somthing that's 100% contradicted my previous believe so if I'm outspoken now .... it's based on factual experience.
I hope you're enjoying your system ... mine was "OK" .... until I made some recent changes, including upgrading the DAC ...... I'm now blown out of the water with it ..... just hope you're enjoying you system as much 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀 😀
There are lots of articles "out there" describing results of ABX testing. You may view the post I am linking to (from head-fi.org: 2010 but updated in 2024) and you may view it as biased and quite a lot of the historical links are now broken. Feel free to trawl through the 1266 pages of forum responses. I didn't! 😉
However my view is that, in my particular situation, once you get to a certain level of hifi quality the change is components is largely meaningless. I'd expect that replacing my current budget level amp and speakers with something more midrange could make a difference. Anything beyond that and I'm probably looking at a new front room or more likely, house.
A lot of what he says makes sense.
On a slight, but connected tangent, why are some DACs so big? You can fit the components into a cigarette box size case, an external power supply is the same size or smaller. They don't generate as much heat as an amp requiring heat sinks and space for airflow. Why make them the size of an amp other than aesthetics of a system and price justification.
i think people like always think, "Bigger is better " , well not all is measured by it´s size some do others don´t, not a rule as some might thing so
Fascinating thread here, good old fashioned objective science vs subjective comparisons arguments going down, and interesting to read about the difficulties with making subjective comparisons.
Without wanting to ignite the tenor that led to this thread being locked, and appreciating that this is a thread about DACs, I would be fascinated to know, @ToppingSMSL - what made you choose/how did you go about choosing your own DAC (D50 III?) and other hifi set-up?
Status
