This has been stored in a dry box for 20+ years. I want to play it but where do I start? I don't think I can simply plug in and play?
Why not. It's the only way to find out if there's anything wrong with it.
you might expect some noise from the tracking servo but this was normal for this device
it will need a new T4P type cartridge I suspect
"The SL-10 is a complicated machine and its small size only adds to the daunting nature of dealing with a faulty unit. However, the quality of all the components used is high so catastrophic failures are rare. The present fad of replacing all the electrolytic capacitors is unnecessary here, although the correct Matsushita 'M' types are still in production for when replacements are genuinely needed.
Of those faults which do occur by far the most common is caused by the drive belt for the arm getting slack. This is located inside the lid and takes some getting to, but it should be the first port of call when dealing with a faulty Technics SL-10 (or one if its cousins).
The 'lid open' sensor, also located in the top half, is the other common source of problems. Should this fail it can be dismantled and cleaned, although this takes a keen eye and a steady hand. The SL-10 is a sturdy machine so there is no need to remove the platter or the cartridge when transporting it; indeed one can cause damage by doing so. There is a small catch to retain the arm, which should be secured whenever the deck is moved."
cartridge can be found here:-
Ah! A good start.Thanks for your reply. All a matter of confidence. I have found the RCA cable. I thought I had the AC in but discover it is a new one and does not fit!
Ah! A good start.
Ah! A good start.
The AC plug I thought was the one is marked KAWASAKI KS-15F. Do you happen to know which model is needed?
I think connectors varied but if it is a UK edition then I believe it had a simple figure of eight connector.
kenable Figure 8 Power Cable UK Plug to C7 Lead for LED: Amazon.co.uk: Electronics
Free delivery and returns on eligible orders. Buy kenable Figure 8 Power Cable UK Plug to C7 Lead for LED or Smart TV Black 3m [3 metres] at Amazon UK.www.amazon.co.uk
I have taken a cable from my JVC handycam battery charger. And it fits! 2 red lights came on. I will persevere!I thought they were a standard size, could be wrong. Can you put up a photo of the connection rear of deck?
However, it's a very nice deck so persevere and let me know how you get on.
You should be able to find a manual online if you don't have one.
Good news. As I said, after so long in storage the cartridge may need replacing but at least you can see if all functions still operate as they should. Replacement belts should also be available if required
How can I tell if this is the original Technics EPS-310MC moving-coil cartridge?Good news. As I said, after so long in storage the cartridge may need replacing but at least you can see if all functions still operate as they should. Replacement belts should also be available if required
Appreciate your advice, thank you.Google, but if it's been sat there this long best replaced
Let me find out what that means. I will return!Just make sure it has a inbuilt phono stage
The amplifier you get must have an inbuilt phono preamplifier section within it to connect your turntable to. Quite a few modern amplifiers do not have this facility.Let me find out what that means. I will return!
Have not found yet. Maybe I need to sell as is without testing. But can I offer postage, if so how to package it, or should it be collected?The amplifier you get must have an inbuilt phono preamplifier section within it to connect your turntable to. Quite a few modern amplifiers do not have this facility.
It's not as fragile as you might think. Strong box or two and plenty of bubble wrap. Remember to lock tonearm in place.OK good idea. I will try thanks. How best to pack? It must be very fragile. I have no original packaging!
