- Aug 10, 2019
- 2,556
- 4
- 0
Hi all,
First post here - this looks like a very informative place!
I'm looking to add a pair of quality bookshelf speakers to my existing mini-system, a Denon UD-M50. I've narrowed things down to either the Tannoy Mercury F2 or the Wharfedale Diamond 9.2.
In truth, I was all but set on the Tannoy until I started reading about the 9 series from Wharfedale, which according to some is simply an amazing line of speakers for the price. I'll be going to listen to the Wharfedales in about a week. What do you guys think about these two speakers?
One point - I'm a bit concerned whether the Denon will have some trouble driving the 9.2s. I know the Tannoy at 8ohm and 88db sensitivity should be fine, but the 9.2 is 6ohm with a sensitivity of 86db. Not sure exactly how much tougher that is to drive.
My Denon unit is highlighted in this PDF, at the bottom of page 1: http://www.denon.ca/hapdfs/udm50.pdf
As you can see, it's usually sold with 6ohm speakers made by Mission (pictured at the top of page 1), so maybe the 9.2s will be fine. Should I be concerned if I opt to buy them?
Also, is it worthwhile to spend a bit more and move up to something like the Evo2 10 from Wharfedale, or the Epos M12.2?
Thanks!
Thanks!
