You would think after 35 years messing with kit i should no better..listen before you buy !
But, after reading reviews bought a pair of mint Evo 30,s from flea bay very cheap, quite a bit of change from £200.
Love the bass department, no boom very, very good.
The top end, oops ! i think the expression is strip paint of the walls. It,s orrible fizz is the best description, some cd,s are unlistenable.
large lounge two rooms knocked into one, solid wood laminate floor, painted walls, which is possible the problem.
Amp is an original Marantz PM 17, cd Marantz again CD 17 mk 2 Signature, cables Atlas voyager, and Ecosse bi-wire set 2 into 4,
cant give the model no but it is the one that uses 2 different cables for bass and treble..cost a fortune about 7 years ago.
Any body got any hints on a different speaker cable or interconnects to tame the top end, open to suggestions.
worse case, keep the amp and cd and there back on flea bay...
