Not sure if this is known already, but I can't see it listed in issues.
I am using IE8, tried with both normal and compatability modes.
So I drill down to say CDP section of reviews (all sections are affected) and I select a manufacturer and the page then reloads but still with all mfg's devices showing in device brief listing underneath, but then if I try to select a single mfg to search devices on it will work and show just that mfg's products. Then of course you have engaged a filter which needs to be deselected, so you do that and go back to the beginning of this loop.
The workaround is that I have to select the wrong manufacturer first of all, before I can select the one that I actually want.
I don't remember this happening before WHF's www tweaks. Don't let JD leave before this is fixed.... block the exit door with his Uniti!
