System glitch...
shooter
210
WHF team. A glitch occurred earlier when i finished writing up a post. I clicked on Post and it took me back to the sign in page. I don't know if there is a time limit for post writing but mine was around the hour mark and could of had something to do with it, but not sure. I signed back in and had a ban flagged, this is common i know but lost the post in the process. Shooter69.
As far as I know, the site is running in a stable manner at the moment. Apologies for your inconvenience, but not sure what caused your problems...
Thanks for the reply Andrew but it happened again this morning luckily though i copied it before i Posted it.
It may be a timing issue as it took me over an hour to write it up, but not sure really. Also one of the pics didn't make it only the link?
Shooter69.
I've never known the login to time out, using either Firefox or Chrome, do you tick the "remember me on this computer" box when you sign in?
I'm using Safari and never tick "remember me on this computer" box as doesn't work. Don't know why that is either.
Found the problem with the link Andrew there is a [ missing from the start of it. If possible someone at WHF could amend it.
Cheers.
