ianov said:
Yea I have the digital coaxial cable connected in.....
Aha! I think that's the problem! In order for your receiver to get the HD (Dolby True HD or DTS HD Master Audio) signal and display the type of signal on its display, you MUST use an
HDMI cable, not digital coaxial or digital optical. They can't carry the full HD soundtrack, only a downmixed version I believe (although depending on the rest of your system that can still sound pretty good). So if you use an HDMI cable to connect your Blu-Ray and receiver, you should get the correct signal shown on your receiver's display. The only problem with that is if your receiver, with which I'm not familiar, doesn't actually decode HD audio. In that case you'll have to use 7.1 multichannel analogue connections between the Blu-ray player and the receiver, assuming that both those machines have connections for 7.1. If one or both machines does not have 7.1 connections, and your Denon receiver doesn't decode HD audio, then sorry, you won't be getting the full HD audio soundtrack. And I'm almost certain that digital coaxial and optical cables can carry only 5.1 Dolby digital soundtracks, not 7.1 Dolby digital. So that's why the extra two channels are not being carried by the coaxial cable, hence those two channels are not lighting up on your display.
What Blu-Ray player have you, by the way?
