Suitable Speaker outriggers
kellycj
Need a recommendation for some speaker outriggers for my Spendor D7s.
I have two boisterous grandsons who have collided with them on a few occasions and i need something to improve the speakers stability, its the width footprint I need to increase not the depth. Thanks in advance
As you have probably discovered they are not readily available. I know there's a company in the States that makes them for my Acoustic Zen Adagio speakers but depending on where you live you might just have to find somewhere that can drill and thread a bit of steel bar to fit.
The one size fits all supports from Townshend Audio are very expensive, their Seismic Isolation Corners are £795 for four.....
