Question Suggestions for foundational parts of a longer term vinyl setup
Thanks guys. I have a loose plan now which will be spread over (at least) several months - more likely a couple of years.
I'm going to demo some speakers at the local Richer Sounds in the coming weeks. I'm setting myself a budget of ~£1,000 per component now as that feels like it should be enough of a jump from my current kit and if that extra spend doesn't produce audible results, then I'll stick with what I have. Taking on board the above, I need to move on from reading about and watching reviews, to plonking myself down in front of stuff and listening to it.
I'm going speakers first largely from a political perspective - my wife won't be as annoyed if I replace kit that she knows is 15+ years old. I've earmarked the KEF LS50 Meta and B&W 707 S3's as my two contenders, having read and watched about a number of options roughly around that price point. My amp should just about have enough grunt to drive them and IF there's an audible improvement then that leaves the door open for me to upgrade to a more powerful amp when the dust settles. I notice that Sevenoaks bundle my amp with these speakers so hopefully that implies they're not a woeful mismatch.
Happy for any suggestions about other speakers to audition, and any feedback as to whether or not the general plan is in the wrong order etc.
Reactions: Revolutions
Sounds like a plan. There are other speakers I could suggest but it all depends on whether or not you can actually audition them, and that's the problem for many.
When I audition stuff at Richer Sounds, I have an issue - they don't stock Rega at all and they don't stock the WiiM Mini either. I'm not lugging my stuff there as I'll be going on the train.
I am now intending to audition speakers AND amps because I'm like that. Is it too simplistic to hope / assume that if I audition those components alongside a budget CD player as a source, that I'll be hearing the combined influence of the amp / speakers rather more than any flavour the CD player might add (it seems unlikely to add much influence?), and that those sound characteristics should be retained if / when I buy these components and get them home to my sources?
Ultimately, when you audition a system, the main components you really need to audition, preferably at home, are the source and the speakers. The amplifier assuming it has sufficient power to drive the speakers, is not critical.
Reactions: RTHerringbone
This would have been a very long post if I'd posted the original, but nobody needs that 😆
Auditioning day was Saturday and the conclusion on amp was: either the Arcam A5 or A15 sounded "better" to me than the Audiolab 7000A. There wasn't much in it and I suspect my previous Arcam experience (I had an A18 FMJ 15-20 years ago) and the aesthetics played a part. I felt that maybe to my ears the Arcam's were more coherent and musical, whereas the Audiolab was a bit clinical and perfunctory. It was splitting hairs really.
Speakers were perhaps easier to judge. The B&W 707s and KEF LS50 Meta's are both similar in stature to my RX-1s and both sounded markedly better than my RX-1s (though that's through superior amps to my PM6007). Obviously the demo room played a part as it isn't a kitchen and doesn't have a kitchen island where the optimum listening spot would be.
The KEFs seemed more versatile in the sense that the presentation felt more consistent regardless of where I moved in the room and that's important with how our Hi-Fi is positioned. The B&W's seemed to create spots in the room where they felt a little muted and less "full". In my head, I had visions of a sort of sweeping 3D arc of sound from the KEFs and more rigid columns of sound coming from the B&W. I did also feel that the B&W were struggling a bit with high frequencies. I can't put a finger on it but they seemed like they'd possibly be a bit of a challenge to listen to for a prolonged period.
So the KEFs won my vote here and in spite of personally thinking that the A5s worked fine with them at the volumes I listened at (lots of online blather cites how hard they are to drive and you MUST HAVE MORE POWER), I am pretty much decided on getting the A15 with the LS50 Meta, which no doubt was influenced by the fact that I know Peter Tyson bundle them on budget. The A15 theoretically gives me a more versatile platform that the A5 moving forwards and I *think* there's some argument that it'll push "cleaner" power to the speakers than the smaller sibling.
It's a flawed audition and many factors inevitably mean it couldn't be like-for-like with our home environment, but you have to draw a line somewhere. I'm set to take the plunge tomorrow (just waiting on a guitar sale to take the edge off this splurge) - are there any observations, similar experiences, words of warning or other recommendations that I should consider before dusting off the wallet?
The guitar sale is being held up by 24 hours so that means more procrastination. Make me stop.
Is there any sensible reason why I would get an Arcam A25 over the A15 given the relatively small listening room (really it's 5m x 4.5m, but as it's open plan it could be viewed as 10m x 4.5)? I'm conscious that I'm tying size and power together and could be wrong to do so.
We'll never want to play loud but are there other benefits to more power that I'll get? I'm just falling for the way Peter Tyson bundles work. It's basically £100 more than the A15 bundle with LS50 Meta and the price difference between the amps is £400, so it feels like there's some level of value there - but is it value that will translate to my circumstances?
A15 puts out 80w at 8Ω and 120w at 4Ω, compared to 100w and 165w respectively on the A25. The A25 bizarrely is in a smaller shell than the A15 and weighs 1kg less. The A25 is a Class G compared to the A/B of the A5 and A15 and has a slightly "better" DAC.
Is it an extra £100 well spent or a totally insignificant upgrade given the constraints of the room?
I would say yes, if you can afford it go for the A25.
Class G amps can be constructed in smaller boxes, as you note, down to the other components necessary to create an amplifier per se.
More power doesn't mean you can simply play louder but that the speakers are more easily driven and controlled, the power into a 4ohm load can be important. Some amplifiers can deliver twice their 8ohm figure into 4ohm load.
Get a pair of less efficient speakers in the future and you might regret not going for the A25.
Bad news and good news.
The guitar sale fell through 😥
But I just ordered the A25 and LS50 Meta's anyway 🥳
I can afford it and just wanted the minor offset of the guitar proceeds to make me feel marginally less extravagant, but really I don't care and figured that life's too short to dawdle. I've bumped the length of the free supplied cable up to the length I need, and really these items plus the Rega Planar 1 should largely be it for me for a long time.
Having said that.....I'll always leave the door open for options to replace the WiiM in future, and I need a dedicated bit of furniture to house this kit and our record collection. Any recommendations welcome there too.
EDIT: I've discovered Lägom Studio online and their furniture seems very flexible and reasonably priced.
EDIT2: I like that Lägom Studio stuff so much I've enquired about a small bit of bespoking to their Solna cabinet:
Reactions: Messiah
It's "new toy" day (again!) - but not until about 5pm.
Dealing with Peter Tyson has been great so far and assuming that the delivery pans out OK, they'll be pretty highly recommended. All contact (email and phone) has been quick and friendly. They offered decent Trade-In for my outgoing kit and arranged for DPD to pick that up when the new stuff arrives later today. They also claim that they wouldn't ordinarily Trade-In two things when selling bundles, so I have done alright there, and they upgraded the cable length for free too.
Very excited to get the new bits up and running later today. The outgoing components have varying levels of service - one month for the amp and ~17 years for the speakers.PXL_20250130_084807964.jpg
Reactions: Messiah
And I've just ordered a minor tweak to the cabinet linked in an earlier post. I'm getting it changed so there's a single vinyl box at the bottom (on feet) and then two 15cm high isolated amp shelves stacked on top, rather than one amp shelf and another vinyl box.
No changes to the price and I think it looks great. The customisation options mean that it'll be a perfect bespoke fit and a much better solution than our current IKEA Kallax bodge.
There's a six week lead time as it looks like they actually make them to order, so hopefully the quality is as good as it looks online - the reviews are overwhelmingly positive.
Good to hear.
One reason I bought my current HiFi Racks piece was the ability to order any leg length you liked.
Good to hear.
It just seems like the right thing to do. It would be missing a trick to acquire nice things and then house them in a "make do" cabinet. The height of this unit will coincidentally be perfect for the turntable.
After this my only (expected) upgrades can be the WiiM and the headphones, and they can wait as they don't feel like itches that need scratching. I did specifically ask for an extra "amp shelf" in the cabinet with that WiiM change in mind..... 😇
Very sensible to plan ahead even if it may cost a bit more, enjoy!
One happy bunny.
When I moved from Sonos & Spotify to the setup at the start of this thread (just a month ago), I assumed it would be impossible to get that sort of leap in quality and enjoyment again.
It's early days, but first impressions are very positive indeed. I've listened for five hours this evening; three through the speakers and two through headphones, and it's lovely.
My wife's first feedback was that the speakers lack bass and were treble heavy, and I think that's possibly down to the contrast to the RX-1s which definitely had more of a punch in bass terms but were pretty muted in higher frequencies. I think once the KEFs have had plenty of use and our ears are attuned, those early observations should level out.
I'll spend a bit of time tomorrow tinkering with placement to see if there are tangible differences with some positioning changes.
What has struck me most is the startling leap in clarity, the soundstage and that feeling of hearing things I've never heard before in very familiar songs. It also sounds very clean and perhaps deceptively feels like we can listen at a higher volume without any degradation in quality or fear of irritating the neighbours at all. Maybe that's just the fact that it all sounds so crisp and clear whereas perhaps the prior setup rather squashed the range a bit.
I also received an update from the cabinet makers - I'm #223 in the queue but they still expect to deliver in mid March.
One happy bunny.
You have the same dilemma as me on my conservatory system I sit with my back to the speakers. How do you define what is left and right.
The sofa usually only comes into play for late-night listening through headphones. In the "speaker hours" we're usually cooking directly opposite the speakers or perched on the island so a conventional left/right setup is appropriate for us.
The distance between your speakers is very large. My setup on my main system because of the room layout is that the speakers are only 1m each side if the turntable but I don't get any feedback as my turntable is well isolated and just below the bottom of the speakers. Here is a picture of my main system .
I think I'm probably taking the KEF LS50 Meta's reported soundstage to the limits @camcroft ! They are far apart but there's no lull in the space in between (there really wasn't a noticeable issue with my prior Monitor Audio Silver RX-1s either. I'm sure there may be a more optimal setup and maybe I'll look into that when the new Hi-Fi cabinet arrives in March.
I am sure that I had a conversation with you about the RX1's before. The way my system is set up it shouldn't sound good but it does.
One happy bunny.
Bass wise she isn't wrong, sonos have a very forward bass presentation, it makes them sound exciting, Its actually very hard to match that presentation with hi fi with small boxes. Ill say its an entertaining sound
She willl get used to it, and if you ever go back to sonos she'll notice that its actually overbearing and bloated and some what muffled because of it .
The problem you'll find in that space is you have alot of hard surfaces hence the your wife treble comment and you have them very wide apart. so the mid bass wont propagate correctly leaving holes/dead zones in your sound stage in regards to bass so when your walking your around you'll notice parts of the room will sound deeper than the rest . But it is what it is in that space and we all have to make compromises in position unless you're very lucky.
A lovely tidy system.
Reactions: DougK1
It was actually the comparison to our previous Marantz PM6007 + Monitor Audio Silver RX-1s that she felt sounded trebly and lacking in bass. I think after a few days with it, she has warmed to the sound and certainly from my perspective, the clarity this system gives is streets ahead of what we had before.
I shuffled things about a bit to narrow the yawning chasm, and the difference is obviously very noticeable and sounds far superior. The new cabinet will be a touch narrower than the temporary IKEA thing, so there can be more minor adjustments in about six weeks when that arrives. The sofa isn't really a speakler listening position - that's more for nighttime audio through the headphones.
Reactions: twinkletoes
Has it changed the sound any since you re-arranged the layout of the system. Ooops I see that you did mention that it does. Enjoy.
It'll sound like I'm laying this on very, very thick, but in general and not just as a result of the reshuffle, this sounds so good to my ears.
Currently I'm listening to fairly gentle music (Hania Rani, Katie Melua, Norah Jones) and it all just sparkles. I work from home and have migrated downstairs to "work" for the past couple of days, but I keep getting up to stand dead-centre and hear it in all its glory.
I'll admit I'm pushing the volume up a touch, but the soundstage and clarity are honestly giving me goosebumps on occasions. I can't fault it. This sort of music is packed with cello and piano and it's just magical.
You are benefiting both from better positioning of the speakers and more forgiving speakers. The positioning was always the weakest link in your last setup, to improve it in two ways will have given you a big jump.
My nightmare of a brain and itchy wallet finger are getting jittery again. I'm just pondering the merits of upgrading the WiiM Mini purely at a theoretical level at this stage and trying to understand what costlier kit actually gets me. I would imagine that they should offer better build quality and components, but whether than translates into audible benefits is another matter.
One thing I've noticed is absolutely zero coverage anywhere of the ARCAM ST25 and I find that really weird. The A5/A15/A25 have all had plenty of reviews and the ST25 is available to buy but there's not a single review anywhere of it. I find that rather perplexing so have asked ARCAM what that's all about because that alone is enough to put me off.
Is this common? I'd have assumed that if you've just had a successful launch of a new bunch of amps and you follow that up with some new streamers, that you have the chance to snare a bunch of sales. The ST5 received a lukewarm reception, so does this imply that ARCAM know they've launched another sub-par streamer and so they haven't sent out loan units for review? Even then, I'd expect stockists to put out some sort of coverage.
It's very odd. I think ARCAM have a couple of all-in-one streamers due to release imminently (SA35 and SA40) but that shouldn't delay reviews of a standalone streamer, should it? They are somewhat positioned as a "family" of products (even though you'd never buy all three), so maybe that's it.
