- Aug 10, 2019
- 2,556
- 5
- 0
I ahve a Denon 1910 amp with a Pair of Wharfedale Diamond 9.5 on front and ahve a Wharfadale PC 10+
After making the audessy setting, the sub was set at -12db buy the system at half volume on the master volume on the Sub. With movies it sounds really good with the sub delivering clear and deep thuds, but with music there is barely any difference, on the spec sheet of the 9.5s, it is stated that the Speakers extend from 30Hz-24KHZ, Can anyone tell if music will sound best with the sub turned off or will the sub still go to lower frequencies (The sub's Spec sheet says it goes to 35HZ)
Thanks.
Thanks.
