Subwoofer connection help
Hi All,
I havre had a sub sitting there for some time not used and I am thinking about seeing if I can integrate it back into my system. Its a Ruark Log Rythm and only has phono connections or a Neutrik connection but I'm not at all sure how to connect it to my Yamaha 1067 in terms of the best option.
Anyone got any ideas? There is a picutre of one here on another forum (not sure if posting links to other forums is allowed, apologies if it isn't): EDIT: REMOVED, obviously not, but a search of google images provides some pictures so you can see the connections.
Any advice appreciated.
I'm no expert but I think the neutrik is the high level connection and the phono connection is low level. Connect the low level to your Yamaha AV reciever via a phono cable. If you also have a stereo amp connect that via the neutrik. At least this is the advice i've been given. hope it helps.
grdunn123:Single phono lead from 'subwoofer out' on receiver to sub should suffice.
Thanks, to the red or white connection? Also I have a sub pre out and 2 sub connections on the amp, which one do you suggest?
grdunn123:From the pre out, single cable to the left hand (white) input on the sub
Thanks, I'll give it a try.
