Stylus upgrade on Ortofon red
Papa Shark
10
Has anyone upgraded to the 2M Blue Stylus on their Ortofon 2M red cartridge?
Al ears
Moderator
I am sure they have. However it might be better in the long run to replace the cartridge entirely.
The replacement of the stylus takes your cartridge up a level but, ultimately, that's as far as you can go.
Papa Shark
10
thanks although from what i understand the blue stylus will be a significant upgrade as the present stylus limits what this cartridge is capable of. and for lazy me a plug & play upgrade.
Al ears
Moderator
It will be that but as far as you can go with that cartridge.
For about £118 you will not find much to beat it but that's OK if you find it suits your needs.
DougK
831
509
11,770
A not so common upgrade is mounting a 2M Bronze stylus in the cartridge, no one recommends it but it is a straight swap :) and a significant upgrade.
Papa Shark
10
that's something to think about, wonder why no one recommends it? must a reason.
DougK
831
509
11,770
Because the Bronze and Black share an upgraded cartridge, mounting these on a Red/Blue cart you will only achieve about 80% of their potential, but that is far more than the upgrade from Red to Blue will ever give you. It's a cheapskate upgrade that no dealer or Ortofon would ever agree with... not recommended, or words to that effect.
To my ears the Bronze is the best stylus in the 2M range.
myrrhman
49
31
70
My recent OM5e to OM20 stylus upgrade was probably the old-school equivalent of a Red to Blue - I'd thoroughly recommend it
iMark
289
96
18,970
I bought an Orfofon 2M Blue stylus in October last year when there was a discount for 100 years of Ortofon. It's even got a fancy "100" on the stylus. The stylus is definitely nicer sounding than the decent 2M Red. I would recommend the upgrade. I ordered it in the UK and paid GBP 110 including shipping to NL. Quite a bit cheaper than the EUR 159 (without shipping) they charge in NL.
Our player is a ProJect 1Xpression III Comfort which came with the 2M Red. Best sounding record player I have ever owned.
Reactions: Greenwich_Man
gfong
13
Did this back in 2011 on a Project table and really liked the upgrade from Red to Blue. Whatever you liked about the Red, the Blue does better and also has a lower noise floor which helps out a great deal while listening to softer music. The Blue tracks well and no inner groove distortion.
As some others have stated, just get the Blue stylus and save some bucks as the Red/Blue bodies are the same, unless you can get a great deal on the entire cart, which would make selling the Red easier with a body. Good luck on your choice.
danny-79
40
23
45
Hi. My first post here. I was about to ask this question. I’m upgrading from red to blue. The cartridges are identical (apart from the colour of the lettering) so I’ve just ordered the stylus by its self.
If I go any further than blue , bronze I’ll order the whole thing.
But for now. Blue stylus is in the post !
danny-79
40
23
45
I hope you are enjoying the blue.
For the price it’s a fantastic upgrade. My Red had quite a few miles on it when I upgraded so wasn’t at its best to be able to give a genuine A-B comparison but I’m extremely happy with the Blue (for now at least 😜)
ASK THE COMMUNITY
