Stylus inspection
6and8
87
9
Want to get magnifier / jeweller's loupe to inspect stylus for wear / damage - what magnification would you recommend?
(I need to wear glasses for reading and fiddly stuff.)
Any particular devices good for spectacle wearers?
AntAxon said:
A handheld digital microscope. They start around £20 and you connect them up to your computer. Try Amazon.
I'd keep it simple. Use loupe x10 this should be sufficient. No need to go to the expense of anything else. You'll use it infrequently and should be able to identify significant damage with it .
