tino said:You could try a QED uPlay apt-x Bluetooth receiver and Creative apt-x Bluetooth dongle for less than £100 new. OK you might notice some compression artefacts in the transmitted music, but not that much. It's a good enough technology solution for Chord Electronics, so I think it should be fine (I have a Chordette Gem which is great for audio streaming via apt-x). The added advantage of this approach is that your student pals can play their i-thingies or tunes on their mobile phones onto your system when they pop round, no cable swapping, logging on to wireless networks or sharing files via memory sticks. Just pair up over Bluetooth and go. The QED uPlay should alo be able to sync up to 4 separate devices (but not play them all at the same time).
Another budget option (assuming you already have a phone or tablet) is to use a phone/tablet to control the music player software on your laptop which is plugged into the hifi. It does mean however you won't be using the laptop away from the hifi for other things while you are listening to your music.
PS I'm aware that there are USB wireless audio streamers, and Apple Airport Express ... maybe one of these might work for you, but can't vouch for the quality of the internal DACs.
Thanks for the reply, I was under the impression that music via bluetooth was a big 'no, no'? But perhaps not, I'll look into them thanks.
The airport express that you mentioned is looking like the best option at the momment, but i'm worried about connectivity issues - but not much I can do about that either way I guess. I lke that you can upgrade it later with the digital out/headphone socket thingy.
Must have posted at the same time
