Streaming from iPad to speakers recommendation.
I was wondering if anybody could recommend a set of wireless speakers for use with a newest generation iPad?
I have looked at the Sonos set up but was wondering if anyone could recommend anything similar?
Thanks in advance.
Well I've always preffered using an Airplay device instead like the airport express (65 pounds) or apple tv (99 pounds). That way you could always change your amp or speakers without changing your source. If you do want to have a one box setup I would suggest the Zeppelin Air or the Beo Play a8. Hard to recommend stuff if I don't know your budget.
