Hi
I'm after another Streamer. I have been using the WiiM mini (now given to my son) through my CXA81's internal DAC Optically connected . I thought the quality of sound very good even though it's so cheap! I only use Spotify. Not into Hi Res Audio, CD quality is fine for me.
Been looking at the MXN10 which has an ESS DAC onboard but not sure which, or if equal or better than the CXA81's ESS Sabre ES9016 DAC.
What about the CXN V2 which has Wolfson WM8740 DACs? I know the circuitry plays a big part as well as the DAC so I believe!
So one question I have is ....Do I get a streamer with good streaming/audio and use the CXA's internal DAC or go for a streamer with a better DAC than the CXA? Cheers
(Spend in line with other components but not sure if £500 max is OK, new to this, equipment used in sig) TIA sorry that's more than 1 question!!
