richardw42
- May 2, 2010
- 299
- 0
- 0
S*** This thread makes me want to scream.
Whf, I had to edit this post I thought the filter would sort it.
richardw42 said:S*** This thread makes me want to scream.
Womaz said:CnoEvil said:I agree with David (and BigH).......these things should start under the Source and then work towards the speakers.
problem em is I have two sources and def not paying out for 2 lots of these 🙂
I am also just following what my dealer said ........thanks for the input though
CnoEvil said:Womaz said:CnoEvil said:I agree with David (and BigH).......these things should start under the Source and then work towards the speakers.
According to this, it looks like your dealer is on the right track: http://www.theaudiobeat.com/equipment/stillpoints.htm
"After the AC supply, your order of application should simply follow the potential energy in the system: power amps, external power supplies, preamp, source components -- in that order. "
pauln said:richardw42 said:S*** This thread makes me want to scream.
Me too.
The fact that some people spend that sort of money on a product like this is verging on obscene and the fact that some people actually believe the claims made about the product leaves me speechless.
Sorry if that upsets anyone but that's the way I feel about it.
Womaz said:but the girlfrirnd who is a lot younger heard a difference straight away. As did my daughter who is only 21 so hearing should be better 🙂
Womaz said:I left them in my system for over a week, and then took them away. it was then that I noticed the difference. The music sounded a little dull in comparison.
So they have been purchased and I think they are a "tweak" that is affordable and cost effective.
CnoEvil said:Womaz said:I left them in my system for over a week, and then took them away. it was then that I noticed the difference. The music sounded a little dull in comparison.
I'm glad you tried it and made your own assessment.
It is slightly bonkers that it has such a noticeable effect; which is why people who haven't heard it, will queue up to tell you are mistaken.
cheeseboy said:Placebo....If a 10k system can sound better with a few bits of metal lobbed under t'amp.....
hifikrazy said:cheeseboy said:Placebo....If a 10k system can sound better with a few bits of metal lobbed under t'amp.....
I'm always amused that people like these are never able to express their skepticism without the use of the words "snake oil" or "placebo"
