Question Stereo Amplifier advice to match current system
DaveyLounge
Hi, I am looking for advice on purchasing a Stereo Amplifier to match my system. Most of the music I listen to is on Vinyl. My budget is limited to £1000 max, preferably around the £500ish mark.
My system comprises of
B&W 606 S2 Anniversary Edition Speakers on Atacama Stands
Chord Rumour X Speaker Cable
Pro-Ject Debut Carbon Evo Turntable
Rega Phono MM Stage Mk3
Marantz 74CD63/15b Special Edition CD Player
Denon DRM-600 Cassette Deck
My current Amp is a Cambridge Azur 540A.
Any advice would be appreciated.
The Rotel or Rega would work great, though the Rega may work better with the slight brightness of the B&Ws.
Your budget would stretch to an Elex-R, but I doubt you'd see any difference in your system, and the Brio offers a huge amount for the price.
Why, i remember whathifi saying the rega brio r is a little bright sounding
I originally had been looking at the Marantz PM6007, Cambridge CAX61/81 and the Arcam Sa20. I would like to keep the Rega Phono, and was wary of having an empty phono stage on an amp. I was hoping to connect the CD player & my TV, for stereo only, via digital optical leads. I have a separate A/V Setup with a projector, for movies.
Can you clarify, you want an amp without an internal phono stage?
Reactions: DaveyLounge
No, it's not. Read his original post. I have offered my advice.
The idea that he might have an empty phono stage on an amp is ambiguous.
NO, mabye he just doesn't wnat to pay for something he is not gonna use like i wouldn't buy an amp with digital inputs since i have a good Topping E30 dac
Your current CA 540a seems like a good little amplifier. I just wonder how much of an improvement a newer £500 amplifier is? I can't say for certain as I have not used the suggested options.
I'd cautiously say upping your budget to the limit (what else are limits there for) may be a better option and would survive a few upgrades elsewhere in the future if desired?
It would put you in the realms of a s/h Hegel, even a MF M5si (if lucky) and others. - All probably a sizeable step above what you have.
The question is what would you like to improve and what are your preferences?
Both the Cambridge Cxa 61 & 81 have caught my eye. My Cd player was linked to my A/V system but has now relocated to my dedicated music system, therefore I would prefer Digital inputs for the CD player & TV
Sorry, I do not have experience of any of those.
External DAC's are cheap and good now so perhaps do not base your decision solely on that?
A Hegel H90 has a good DAC though. I did own this amplifier and it is very good imho. How it compares to your choices I can't say but you can pick one up s/h under your budget.
CA make good products and a lot of users seem happy.
the cambridge 61 costs as much as the cambridge 80, thats why i didn't mention cxa 61/81
The cxa 60 has a very open sound not to much bass and a more bright sound than dark, so make shure nothing else is bright
