The_Lhc said:professorhat said:To change everything to static IPs, you don't really do anything on the routers
Although it might be easier, depending on the router. My router gives me the option to fix an IP address for a given device, so it's still using DHCP but will ALWAYS give out the same IP to the same device. That makes it a lot easier to manage, you only have look after one lot of settings (the ones on the router). Easier than manually setting every device.
sounds like a good option.
