drummerman said:
How is it going with the Sony?
What can I say... probably one of the best value amps you can get. Large and built like a tank with 110W per channel, DAC, phono stage, headphone amp, tuner and that's not to mention home cinema features which don't interest me. It's incredible considering it sounds good too. And that's for circa £100 or even less. I've had a good number of second hand integrated amps at this price point an none offered nowhere near in terms of features/quality/power.
Sound quality wise there's a lot of good and remember I compare this av receiver against stereo amps at 2-3 times the cost when new. I've done some listening with Dirac and some without. Also used Sony inbuilt DAC as well as the one in Yamaha. As a straight up amp when fed analogue signal it sounds best imho. It may have something to do with superior DAC in the Yamaha as opposed to amp capabilities. Inbuilt DAC is very capable and accepts hires signals but soundstage feels smaller or should I say most instruments/vocals feel bigger than they're supposed to and this gives away a feeling of a more congested and smaller soundstage. Yamaha can also digup some more detail and it just sounds clearer. It's not to say the inbuilt DAC is poor but the fact is Yamaha is better.
When measured is shows less extension and overall control but that's to be expected. By ear it's neutral and natural. It's musically satisfying though and happy with just about any genre. Rock/metal has enough of power and energy, jazz enough subtelty and richness of tone, layers of instruments in classical are adequately recreated. The amount of micro detail is less than I'd like. Also the amp has less clarity and soundstage feels smaller than Primare even with Yamaha DAC. Yes, I'm aware how soundstage and detail are a signature thing for Primare so no surprise here either.
One thing I'm sliglthly struggling to understand is how it responds to volume or really of my reaction to it. When I turn up either of Primare I get more, sound feels the room, details is easier to notice, etc. When I increase the volume on the Sony it's just louder... that makes it less comfortable to listen to especially with volume pot that isn't as good as on Primare. Don't know if it makes sense. I've been trying to put it down to higher THD but are my ears so sensitive?
As a side note. A week and a bit with Dirac and I'd like to retract something I said in an earlier post. I can hear differences between amps post Dirac so amplification still matters and not just the power stage. A first stumbling block to this little project, but won't give up just yet. Learning quite a lot so all's well
