speakers for roksan caspian
cse
97
Any ideas on some suitable speakers foe a roksan caspian amp. I listen mostly to classical music. Also is it worth getting the amp serviced, if so, roughly what would you expect it to cost?
Thaiman
360
Roksan FR-5
Andy Clough
776
Depending on your budget, and whether you're after standmounts or floorstanders, I'd look at the likes of ATC's SCM11 (£850), Dynaudio's Focus 110 (£850) or Dali's Ikon 6 (£899).
cse
97
I think I'm after standmounts, around that budget. Musn't be bright soundinding. I listen mostly to classical. What about PMC or Proacs?
Andy Clough
776
Proac Studio 130 (£1135) and Studio 140 (£1440) are both excellent, but are largish floorstanders.
PMC do a couple of excellent standmount speakers: the DB1+ (£675) or DB1-S-A (£1169). The latter are small in stature, but create a phenomenally expansive, punchy sound. That help?
JoelSim
767
[quote user="cse"]
[/quote]
ProAc Tablette Reference 8 Signatures are fabulous small speakers. I have some Dali Ikon 6 floorstanders too and the ProAcs are at least as good, but faster and more forgiving.
