hi, i recently replaced my cambridge audio 640 v2 cd/amp with wharfedale 9.1s with a roksan kandy mk.lll cd/amp and dynaudio audience 42.
i am on the whole extremely happy, its a massive improvement on my previous system, which i found too bright for extended listening.
i auditioned the kandy kit with kef iq5 se and monitor audio rs1 as well as the dynaudio 42's, and while i liked the kef's as well i preferred the treble from the 42's, the kef's sounded a bit harsher to my ears. so, i like the treble and the way voices sound, and there's tons more punch and a faster sound then my last system, why am i thinking of changing the speakers? this is where it gets tricky as i'm a relative novice to hi-fi and might not describe what i mean very well. my slight gripe is with the bass which i sometimes find hard to follow, there's generally enough of it but it doesn't seem as clear as the rest of the sound. i wouldn't mind a bit more slam from drums as well. my main issue though is i have to place them at least 55 cm from the rear wall or the sound gets a bit full/boomy and my living room, akwardly L shaped, isn't very wide so they intrude a bit more then i would like.
what i'm after is a speaker with a similar treble to my 42's and hopefully improved bass. i mainly listen to rock music from the 60's to present day and am willing to spend up to £1000 on the speakers if i like them. if my memory serves correct a review of the proac studio 110 and atc scm11, said that both could go near a rear wall? both would require some travel to audition which i don't mind, do you think these could give what i am after? any others i should consider?
also, i've not read any reviews of my dynaudios other then the snippet in the back of whathifi. could anyone describe the sound from them as it may help me describe what i am after to a dealer? i have only ever heard the speakers mentioned above and wondered why they got four stars, it might help me isolate good and bad things about them and understand why i prefer one speaker over another.
thanks, craig.
thanks, craig.
