Speakers for Cyrus pre/power system
gingersmarty
58
Hi All,
After a bit of recent tinkering i find myself with the following system:
Cyrus CD8x
Cyrus Pre x vs
Cyrus X power.......
and a hang over from what went before in the shape of a pair of Epos M12.2, i actually like the overall sound i have and was wondering if anyone out there had a couple of options for a speaker that would give me a little more of everything so i could arrange a home demo/audition.
Thanks in advance.
Sean
gingersmarty:
Hi All,
Cyrus CD8x
Cyrus Pre x vs
Thanks in advance.
Sean
The hint of a suggestion of surprise suggests that you "did a Joel"? The journey to where you got is as intriguing as where you will end up at!
Back to your question, maybe Spendor A6's as they perhaps balance the leanness of the Cyrus, and I'm sure that the resident dealers will suggest some ATC's.
Where do you feel the speakers you have let you down? What do you want to improve? What size room do you have? Close to walls or in free space? Do you like your music quite loud or just moderate levels? Any preference for the size of the speaker?
