- Aug 10, 2019
- 2,556
- 5
- 0
HI all, I have been using my old Mirage M190 speakers with the 650A for a while, good midrange but a bit bright in treble and the bass is somehow weak and coloured, perhaps due to the medicore construction of the speakers cabinet. Source is using Macbook with Acram rDAC playing FLACs.
I don't really have the oppotunity to audition different speakers in where I live, so my knowledge are pretty much based on the research I done on the internet. After searching non-stop on google I narrowed down to a few but I don't exactly know how they would sound with the 650A. Lots of comments saying this amp is on the lean and bright side so I probably need a pair of more "neutral" speakers to go with.
Current choices are
Monitor Audio RX2
B&W 685
or others within the similar price range?
I believe the 650A are good in producing a wide soundstage and precise positioning. So what I am after is clean, deep and tight bass and less clincial in treble. My choice of music are from vocal to Jazz to rock and electronics, so I guess it will be hard to find a pair of speakers that caters all types of musicm but I prefer not to have a too warm and "slow" sounding speakers.
Some say the RX2 and 650A will be a good combo but some say it will be too bright, while for the 685, I have no idea how it will match up with my amp.
Thanks for help.
Current choices are
Monitor Audio RX2
B&W 685
Thanks for help.
