Sorry ... Long post but hard to give the "full impression" in a shortened version.
I've been testing some speaker recently doing "back to backs" with a switch so I can instantly go from one set to another to see which I prefer.
Whilst I've always appreciated how close ther are to a wall, both behin and to the side can have a great effect and placing on a speaker stand helps, to test them I've put one on top of the other (bookshelf speakers) and I've been shocked at the difference in sound depending on which one is underneath as opposed to on top as they're both in exactly the same position in relation to any walls.
Initially I thought it might be that the bottom one was sitting on a full foam speaker isolation pad and the other just placed on top so I changed this and put the small isolation pads under each the corners of each of the sets of speakers and I#m getting excatly the same result.
The one on the bottom sounds rich and warm and the one on the top sounds bright, lacking in depth and basically tinny, I've then swapped the speakers over (top to bottom) and it's reversed the results.
I'm testing them on a desktop which means my ears are then level with the woofer of the speaker on the top and me made me wonder if when they design them it's done on a speaker stand assuming that the listening position will generally be higher than the speaker so the sound is slightly projected upwards.
This also made me wonder about putting speakers on shelves at higher levels and again the effect on the sound.
If anyone can help me understand what's going on and wht it may be, maybe the lower one has a bigger overall area underneath reflecting more bass, but then again speakers on a stand don't.
Just for future I'm guessing if you're comparing speakers it's best to place them side by side as opposed to one on top of the other?
