Hi all…
I was set on buying the monitor audio silver fx surrounds to go with my Yamaha rx-a1010 amp until I read something that confused me. I hope someone can clear it up for me…
I read in the the Yamaha manual that if you use 6ohms speakers for surrounds (which the silver fx are) you have to then use 4ohms speakers for the fronts. Is this really the case? Is there a way round this?… if there's not il have to drop down to the monitor audio bronze series as they are 8ohms. This will allow me to use my quads as fronts as they are also 8ohms…
I look forward to any advise
