Speaker impedance- help!
milesc
8
Hi
My speakers have an impedance of 4-8ohms
Which setting on my receiver do i set?
1). 4ohm ( instructions state: select if the impedance of any speaker is 4 ohms or more but less than 6)
or
2). 6ohm (instructions state: select if the impedance of all speakers are between 6 and 16ohms)
If i select 1). Then that's wrong as my speaker are not less than 6ohms
if i select 2) Then that's wrong as my speakers are not between 6ohms and 16.
Thanks for your help
milesc:
Hi
1). 4ohm ( instructions state: select if the impedance of an speaker is 4 ohms or more but less than 6)
or
Either would be fine. Mine or 6ohm speakers and I have my receiver set to 4ohms.
Hi
Simply thinking I would choose setting two as all your speakers are between 4-8 ohms impedance,. I think your first setting is for one pair of speakers.
Just to double confirm contact the manufacturer.
Hope this helps
n4d5
I think the speaker manufacturers state the lowest resistance the
speaker has.
So I would think that your speaker is a 4 ohm one and
choose the first setting. But I may be wrong.
noble:
speaker has.
But you're not. You're spot on.
Say, for example, you have to pair of speakers, 2 with 4 ohm impendance, and 2 with 6 ohm impedance, than choose the lowest value, i.e. 4 ohm.
